Strizzo
let me see if i can post this in two parts
i had a long post typed out yesterday and then the board crashed. so, to sum up, from looking at your video, it looks like the carb has been swapped out with one from a later model, which has an integral fuel pump, so the thing on the inside of the hull was the old fuel pump.
the handlebar cover has been replaced with a much later one, which is why the button says start/stop. on that ski its only a stop button, the button down by the choke is the starter button. (i always liked this better, you can pull the choke and hit the starter with one hand and work the throttle with the other) they probably used the hole for the lanyard for the extra choke cable, or they might have put a primer on the carb and just used a choke cable to work it.
"where the oil goes?" yep
"fuel selector" yep
"exhaust i guess" yep, thats the water box, it acts like a muffler and also keeps water out of the engine when you shut it off and the exhaust outlet is under water.
"fuel selector" yep
