XP JIM
Hello SeaDoo Forum. I finally bought a 96 XP (woo hoo) and I am about to embark on the path that so many others have taken before me (rebuilding the carbs and entire fuel system etc.). This seems pretty straight forward. I was also going to look at the fuel valve and possibly replace it if needed. I see that there is a screen below the baffle in the fuel tank, is that a concern? I also see check valves and pressure relief valves, are these also a concern? The oil injection evidently works on this ski, but is the consensus to forget about it and just run pre-mix? If so, I believe there is some type of block-off kit to accomplish this? If so where can I get one and do they come with instructions? Lastly what is the ratio of Gas to Oil if I do run pre-mix? 50:1? Thanks for your help
