New 96 XP Owner
mikidymac
Moderator
Staff member
Moderator
Messages
8,736
Likes
586
Location
California
Water Crafts
2003 GTI
2001 XP
1997 GSX
1996 XP
1996 HX
1996 SPX
01' Superjet
#26
That’s why I top my tank off before every trip and always have a gallon of XPS in the trailer box.
Messages
11
Likes
0
Location
N Myrtle Beach, South Carolina
Water Crafts
Finally bought a 96 XP
#27
I finally got to work on the XP (it's in VA at Lake Anna). Pulled the carbs off and now realize the value of anti-seize or grease. Stainless fasteners in Aluminum are a bad combination. I thought the bolts holding the carbs on were going to snap (fortunately they didn't) and I assumed the problem was where they contacted the intake manifold, but they were locked into the carbs themselves. The previous owner cut two appx. 1 1/2" holes in the air box in an effort to get more air into the carbs. I'm sure this probably isn't a good thing? The only other issue is the head pipe was leaking at one of the plugs even though it had been jb welded. Can these be welded? Do you need an Aluminum Plug to weld in? Does anyone offer this service? Thanks
Paul Bretz
Messages
200
Likes
25
Location
New Baden IL
Water Crafts
many 96 xp's
97 gsx
hx 800
#28
I always use grease or anti seize on bolt threads for that very reason. Yes they can be welded. All the jb weld has to be ground away. Any local machine shop can weld new one in. Just make sure its a high grade of aluminum. I have seen one that was welded in a d few years later it was corroded through again due to crappy aluminum, and i mostly ride in fresh water
Messages
11
Likes
0
Location
Water Crafts
#29
Do you have any idea where I can get the proper grade of aluminum plugs for this and what size they are?
Messages
259
Likes
22
Water Crafts
(2) SeaDoo SPX - 1997 (sold)
SeaDoo Speedster SK - 1999
(2) SeaDoo Spark 90hp - 2016
#31
Jim @racerxxx has the plugs you need. He sells them. Then you can have a local welder weld them.
racerxxx
Moderator
Moderator
Messages
10,475
Likes
147
Location
Chalfont, Pennsylvania
Water Crafts
89 SP, 91 XP,(2) 96 XP's, 99 Speedster Twin 800's , 95 HX, 95 XP800, 98 SPX
#32
Let me know how many you need. I can get them out the door tomorrow. They're $5 each plus $7 to ship via priority mail. So if you want 4 it's $27 total.
Messages
11
Likes
0
Location
Water Crafts
#33
I only need one (lucky), but I think I'll take two. Give me your address and I'll send you a check. My info is: Jim Celia 800 East Coast Lane, N Myrtle Beach, SC 29582
Adsense
Usergroup
