Need to remove starter...'96 Speedster
GrampaBigJohn
Help! One of my starters has to come out. Bad bendix, apparently. Got the exhaust out of the way, but how do I get to the bottom starter bolt? I can barely touch it!
bottom starter bolt
On '96 Speedster--Does the bottom bolt go in and out from the back, as the top one does? Can I unbolt the front motormount to get at it?
Dummy Grampa
Dummy Grampa
You are right, it's a 13mm hex head (not allen head) bolt that comes in from the back. Unbolting the front motor mounts will not help. If you are really having a hard time, you can remove the exhaust pipe.
Chester
obviously different too mine, bugger, i thought mine were bad enough.
Thanks for chiming in with the correct answer Chester.
