Need help identifying this line
Joselurod
The line that goes out to the hull of the ski. It has an outlet on the outside. The hose however is not attached to anything on the other end. I can't seem to find anything that it is suppose to be attached to inside the hull. To my knowledge this pwc doesn't have a bilge pump. What is the purpose of this hose? Its a 2010 GTX 155. Maybe someone that has a 2010+ ski can open up the battery compartment and follow the line to see where it leads to? I figured maybe it might have ripped off when the battery was removed for winterization and i am prepping the ski to go the water, don't want it sinking on me!
My 2009 wake 155 does not have the extended vent line, only the vent port right on the battery? Should it have come from the factory with the extended vent line?
yes, wake155, it should have a vent line. look around you'll probably find it, sometimes the actual vent is up front but the tube should be lying around in the area.
