Just purchased a double 01 Shorelander trailer. Noticed the far right bunk looks bent and needs replaced...where can I get this pair of brackets? No place close to me...
Angle steel at lowes, $14.99, lowes stainless steel hardware for installation $5.00, left over rustoleum free...
mark 1" from the edge of the steel, place 2x4 on that mark, mark other side of 2x4, measure 1" from that mark. Cut steel squared at the last mark made. Now cut a 1" square from one side of the steel on both ends. Bend the left over tabs up at a 90 degree angle. Drill mounting hole to fit trailer, drill offset bunk mounting holes so that the screws are not point directly at each other, this helps prevent splitting. Clean and paint brackets. Apply grease to the surface that will pivot against the trailer. Install the brackets for fitment. Align the bunks in the new brackets and install. Remove the bunk/bracket assy and re-install carpet.
:cheers:
