pm sent re: head
1.5 oversize pistons need the guillotines cut for sure. The RAVE housing is well past worn out as you can tell by how worn the underside of the blade is, it was rubbing on the under side of the exhaust port for the longest time. Those are two parts should be replaced during every rebuild. It probably had enough flop to eventually bind and snap would be my best assumption. What scares me is all the metal flake that you might have washed down with the WD and the brake cleaner. I know what it would look like if it were me right now, I just wish you lived closer.
I dont know if they ever made 1.5mm over for 800s...?
Since the head is off put the piston all the way down, jam a bunch of rags in there and go to town. Wait...on the top rag put something on it...oil...what ever just to collect particles.
When you put it back together pour a little 2 cycle down that cyl to make sure shes over lubed.
So I thought I would move this over to a new thread, in order to show progress of what I am doing to my new to me 97 XP. I bought the ski on 1/28/13.
What I will be doing on the ski...
Starter replacement
Cleaning the inside of the hull
Servicing the raves
Replace grey fuel lines
Clean the carbs
Changing pump oil
Fixing/ investigating interesting JB weld, head repair job
Other general maintenance
Hopefully these are all the problems that will get the ski back in top notch form. The outside of the hull is in remarkably good condition for being 15 years old. The VTS works. MPEM gives me two beeps. The seat is in immaculate condition also. I will be removing a couple of "Hardline" decals the previous owner put on it for some reason, but I hope it is a short repair process to get it going. I will try and take pictures and videos as I go for others who are doing some of the same maintenance on their ski's, but dont have the "know how" on how to go about doing them. Here are some pics of what I'm starting with.
Quote]![]()
I love the battery connector, that should pass any CG inspection.....NOT![]()
Holy crap SBT runs those sleeves THIN. I thought they only did that on 951s! scary. Heat dissipation problems come into play with sleeves that thin.
Yep, personally I'd only ever go the first over with an OEM piston, but that's me. 1.5 over is a poor mans big bore kit, LOL. But when your dealt it you gotta run it.
i was going to say the exact same thing sort of,, meaning I didn't think anybody did 1.5 on a 787,,, but since well, maybe I was wrong, i bit my tongue,, but since you brought it up, actually i think i'm right.... SBT doesn't do 1.5.. maybe pmc does.. but not sbt... I believe they (SBT) re sleeve every cylinder, and bore to .5, which is why I give them my overbored cyl's when I do top end exchanges with them. if they are only .5 or stock, I can bore them locally, if they are at 1.0 and need re-bored, IMO they need re-sleeved, so they go into the "exchange" pile.
I'm thinking thats just a pmc thing, not sbt... there might be other differences, which may explain why sbt won't take them as core exchanges.
I just want to make sure that if we're going to throw somebody under the bus, its PMC, not SBT.
