hi everyone. i decided this year to try my luck with changing my own oil. the oil i pumped out looked like normal used oil. i pumped out about 3 qts. and replaced the oil with BPR XP-s (it was recommend by the parts department at a seadoo store) but my issue is; i put the ski in the water for the first time this season last week, and it ran like it had old gas. i figured i would just run out the old fuel and it would clear up. but it didnt.. I decided to pull the ski out of the water after only 30 min of riding, on my way back to pull the ski i noticed white smoke(more then normal) i also noticed the engine was running with a dead miss. i checked the oil and found it was milky, i also pulled the spark plugs and they looked normal. i would normally expect to see one plug that would be extra clean if there was water getting into the cylinder. correct? i found the #1 cylinder has the dead miss(but there is fuel from the injector and there is spark and compression) Im lost and need some direction, any suggestions? thanks
