I have made a leak down/pop off tester... kinda. The problem is that it leaks back through the valve stem and/or the tire pump I use to air it up leaks. which is not good for a leak down test. For those that have made homemade leak testers what pumps work best and what keeps air from going back through the stem? I have looked for check valves and I haven't found any?
(I know I need to get a lower psi gauge, this was the only one at the hardware store)
Thanks in advance
Thanks in advance
