Inline fuel filter problems / help
Ok, I must have installed the inline fuel filter wrong, but can not figure out what went wrong. I installed in
Inline fuel filter during the spring before the season, on both of my crafts 97 GTI and 96 XP. The 96 was hard starting each time after install but would start, 8 to 10 trips to the river, but I just figured it was the new carbs I also installed at the same time, but then this week, the first day out it would not start. I noticed the filter was dry, no fuel in it. so I took the filter out of the system. The 96 started right up, ran two days, no problem starting. then there is the 97, it would start just fine the first 8 to 10 trips, but on the last trip in June, the 97 suffered a bolt breaking off the carb and falling down the carb and killing rotary valve, so after motor repair tried to start, no fuel in the inline fuel filter, took out the filter, started just fine, was able to run two full tank fills of fuel with out any problems. What went wrong, I noticed both inline filters would not be full of fuel, would always have air at the top of the filter when I would check it out, when I had the seats off, but never noticed the condition of the fuel filter while running. Does it need to be mounted below the carbs ?
Thanks for the help, I would like to have the extra protection, both crafts have the fuel lines replaced, 96 has new carbs,and the 97 carbs are only 4 seasons old, always with new fuel lines.
Rich
Are you installing the filter right at the water separator? I had issue like this with one installed right at the stock water separator
What filter did you use?
Was the arrow pointing toward the carbs?
There will be a air space in the filter during use, so don't worry about that.
I installed between the stock water separator fuel filter and the carb, it was about the same spot in the craft as the inline oil filter
I've used that same filter for a couple of years (I do replace it every year) and have not had a problem. Try replacing the filter with a piece of fuel line. I think you have a problem with either the pulse line or in the fuel pump which is in the mag. side carb.
Lou
Lou
Lou
That's what I did and both craft ran great, no problems, that's what is puzzling me, the XP would not start with filter
Rich
