Weebage
Hello, I have a 1998 GSX limited, it doesn't run good at all, it dies when you hold the throttle open for more than 5 seconds, does this at full throttle and mid throttle... then bogs until the fuel pressure builds back up then does the same thing. It also dies when you punch the throttle at all, if you jam it open and shut really fast then it'll go. When it hits the power band for that split second it's got power and sounds great too. Pulled plugs when it died and they were dry, not soaked, which makes me think it's fuel related. Plugs are tan mocha colored.
Here's everything I've tried to do to fix it.---
Previous owner put new lines on it, which are all in the correct spots.
Checked the pressure check valves on the tank, I think they're ok but ordered new ones in cases
Haven't taken the fuel line from the filter to the carb off but all the other lines are clear.
Rebuilt carbs with OSD back to OEM kit. New needles and seats, all jetting was out to stock, I believe it was 1 1/4 on low speed and high speed was 0 on mag and 1/4 on PTO. I followed the diagram from mikuni as best I could. Accelerator pump has new lines that I put on, 7/16 lines, diaphragm was good and pumped fuel. I went thru the entire carb with carb cleaner and air chuck. Filters were clean and replaced.
New fuel filter o ring and filter.
New coil because it was bouncing off the limiter sometimes and sometimes it didn't, after I replaced the coil I started having this new "fuel related?" issue but I don't believe it's spark related, I'm not 100% sure.
I haven't taken the fuel baffle out yet but I was going to blow air thru the top, because it seems like a pain to get it out.
At this point in time the ski will not pump its own fuel, I can blow air and pressurize the line but once it runs dry it will not start. I checked the inline fuel filter and it had barely any fuel in it.
I have no idea what the problem could be, I've been doing research and read something about restricting the return line? Never heard of that but I'm stumped, I'm tired of throwing parts at it. Any help would he greatly appreciated thanks!
