How to replace Choke Cable
shoultsc
I have a 1996 XP with dual carbs. I need to replace the Choke Cable, but I'm not sure what I need to do to take the cable off of the carbs. Is there a special tool I need? Looks like something pressed into the holes to keep the cable in place. Thx, Calvin
There is a nut behind consol at the T-handle, then it pushes into hull thru the opening when its oriented, diagonally. On the carb large pulley wheel is a slot just bigger than the wire cable, the barrel then will exit it (the wheel). Bills86e
