I have a '98 speedster that has been put through its fair share of rough rides. When I hit waves you can hear crunching sounds from loose foam blocking in the hull. I've looked in the storage door in the floor and I can see broken chuncks of "gray glue". Has anyone had to repair the foam blocking in the floor and what did you use? I was wondering if I could use spray foam to help bond the foam back to the fiberglass of the hull??
