Picked this up, looks nice only 52 hours, changed the oil, removed 3 qts. replaced 3 qts 10-40 oil. went to lake, 57-60 mph tops, some cavitation coming out of the hole-3 steps,
holeshot good otherwise, impeller & race looks good otherwise, a little over 8k rpm & 57-60 mph bouncing back & forth with 200 lbs of rider at lake pleasant AZ. , worried about Supercharger Clutch so I removed the intake tube & can only move it 1-1/16 turn either way but it is had to do, seems like it is turning engine over, do I have anything to worry about? Going back to lake 88 miles in AM tomorrow otherwise.
Thank you,
Zok
Thank you,
Zok
