lawdawg_18
Okay sorry if I dont have all the terms and such right but I got in a barter/trade 2 1996 Seadoo GTX's on a double trailer. they are very clean and what i thought to be low hours. One of which has 110 hrs and the other 76hrs. One of them has the Rossier high performance exhaust system on it also and the other one is completely stock from what i can tell. Before i got them me and my brother tested them on the lake and they both seemed to run really good and i got hooked right there. The guy told me that the ski with the rossier exhaust would do around 70mph on a calm glassy lake and the other ski he told me had a rev limiter on it that kept it from going over 35 - 40mph. he said that if i noticed the RPMs bouncing around from around 5000 to 6500 that was what it was doing. Anyway after we got them took them out twice and ran them hard both times on the lake for about 3hrs each time. No problems at all and the stock ski that he claimed to only go around 40 tops was doing around 55 with no sign of the rev limiter on it. The Rossier ski would do close to 62 is all i could get it according to the on board mph. Now after that the stock one all of a sudden seemed like the rev limiter was on it again and the RPMs would bounce up and down and was really annoying. Did some research and discovered it was probably a bad rectifier since i have replaced it but not been out on the lake. The other ski with the rossier exhaust all of a sudden seemed to lose power one day and started only going around 40mph tops and acted like when you had it full throttle it was starving for gas. So did more research on what was going on and realised a lot of things needed some checking. So since then i discovered that both skis had original gray gas lines and i replaced them all and also cleaned the fuel selector switches in both. I hooked the one with rossier exhaust up to water hose at home and cranked it up and found that it was spraying water and exhaust from the exhaust right where they come together at the front of the motor its about a 5" sleeve that the old owner said he had put on it because the one that was on it when he got it was leaking. Well this thing was all dry rotted and cracked and spraying a water mist and exhaust everywhere. My question on that is where do i find another rubber sleeve that will work for this better the one he had on it was a cheap thing that wasnt even designed for this application. Ive looked everywhere on ebay and other online stores and cant find one. It also has the orginal clamp from the orignal exhaust over the sleeve that was the main cause of it splitting and tearing like it did when they tightened it down.
I need something that will work for this asap. Also i have discovered that im supposed to clean the rave valves. So i did as as i had read on these forums and removed them and cleaned them. Now the one on the rossier ski towards the front of the motor had a melted exhaust piston thing that is plastic and holds the spring and screws onto the thing that goes down into the motor. nothing else was damaged but it had a hole melted through it and i ordered a new one. Now both rave valves were so filthy i really doubt either of them had been cleaned in several years or more. The front one was almost frozen in place. Now since they are all cleaned and waiting for a new plastic exhaust piston will they work as normal or will the ski run even better now that they are cleaned? Also i discovered that the exhaust manifold was leaking water from the rear bottom of it i also removed it to find that the gasket was old stiff and dryed out. Now my main conserne is really the rubber boot thing that needs to fit over both exhaust pipes to conjoin and seal them taht is5" in diameter. Also i forgot to mention i checked carbs and the carb filters and all are clean and good looking. Any advice on anything else i have almost gone completely through these now and hope that they will run even better than before. Also i am having a big major problem finding oil for these skis the previous owner said he used quick silver and got it at walmart but the only one i could find in quicksilver at walmart was for outboard engines and was not recomended for pwc. I have been using a brand from oreilly's that is not the twc-3 kind and is recomended for sea doos but i can only buy it by the quart for 3.98 a quart. Okay sorry this was so long but i have fallen in love with these things and really want them to run like they should i hate having them ripped apart but cant stand the thought of blowing a motor for being ignorant. Thoughts tips and advice appreciated. thanks
also forgot to mention changed plugs and so far they look a brown color
