kirkland
2 stroke 951cc engine problems please help!!! ANYONE...ANY IDEAS....
*Please note all details of what's been done is in this story which is 4 weekends of what's happened to my sea doo and what's been done, I hope someone can pick something out of it and help me.*
Ok, this is going to be the long story short, I'm going to try to keep it short. I bought a 2000 seadoo gtx, bombardier three seater, it was in great shape, been garage kept, new trailer, and the ski has 160 hours of use, the guy said he never rode it hard, took good care of it. I bought it for 1000 bucks, a awesome deal, he just said he wanted it out of his garage and was going to get a boat. Anyway it sat in his garage for a year and a half. I never have owned a ski, only rented them a few times and I relize their are a ton of things I need to learn. I got it and got in a hurry to take it out, bought a battery and she started right up, took it out ran it and the over heating sound went off and I thought maybe a sensor went bad, went a min or two too long, relized at that point I was sinking and I didn't put the freaking plugs in the thing. So I had to gun it enough to get some water out jumped off put the plugs in, took a peak at the engine and I knew I screwed up at one look. It wouldnt start so I thought I was going to have to swim it to shore with a rope, lol. I tried to start off and on for 5 to 10 min, after it cooled I choked it one last time and it started, I knew it was toasted so I hauled it to the dock as fast as I could, only about a quarter mile or so. A hose came off the bottom of the tuned pipe, the engine got hot and blew off more hoses. It burnt all the paint, rave valves, gaskets, even grooved the cylinder walls had water in the engine. I do know about engines that's why this is driving me crazy, anyway enough with the story just thought you would find it funny. Within 2 weeks I had took everything apart down to nothing but pistons hanging out, ordered all new gaskets, rave valve parts that melted. Of course I got all the water out, changed my crankcase oil, honed the walls smooth new hoses and clamps from front to back, changed the get pump oil and all looks great there. I have taken it out 4 times since just to test ride it, ran great no problem for 10- 15 min then started skipping, stalling and would not crank. I found out the hard way it takes special spark plugs they were all fouled up I got some from a seadoo dealer set the gap to 0.06-0.08 found a place online that said that. I tried it again in the yard all was good took it out today and the thing ran perfect for about 15 min and got it up to 55 mph and cutting up out there having fun went to go for 60 and it started skipping stalling at around 45 mph, took it back to dock and tried to just take it easy and see if I could tell what it was doing, kept doing the same when trying to idle, if I gave it a bit of gas and it started skipping went dead and didn't want to crank, at one point I thought it wasn't going to crank. It did crank long enough to get it out of the water. I changed the plugs again just to see if it helped and it's hard to tell because it works fine for a little while no matter if the plugs are bran new or have a little black oil on them. Lo and behold it seems to run fine on land now almost every time, I get it in the water and it does that. I did notice that it seems to have something to do with getting it good and warmed up...(I think), because in the yard I ran it for 3-4 min i did rev it a bit, cut if off for a few and did it again for 1-2 min and it started wanting to sputter when you give it throttle and the hose is cold well water which seems to bog it down due to the shock of the cooler water even if I just cranked the engine it will idle till the cold water gives it a shock and I have to give it some gas to keep it running and if i run it for 20 sec with no water it seems to idle great no problems...(most of the time). This really is driving me crazy because I've changed engines in cars, changed everything in cars just about. Never have or worked on a jet ski till now....the guy lost the owners manual so I got a disk from online and downloaded other stuff on my pc. The seadoo is a challenge to work on but I got it all back together and it looks awesome and runs awesome too when it feels like it. The guy did tell me the oil or gas tank (or both) were changed, can't remember which and that's the only prob he had with it, wish I could say that, I'm a newb with the things but I can work on them, I could take the whole thing apart again and put it all back together again in a weekend if I had to with no special tools, my Dad had the idea to make a ring squeezer with thin sheet metal and straps, and don't even ask how I got the nut off the tuned pipe where it goes on the exhaust man....ok I stood on my head inside the thing with a big screw driver and hammer hitting the nut just right to loosen it and tighten it. I was out of ideas and asked him, it worked but after all that this little glitch is killing me. I don't know if he put fuel stabilizer in but is was only about half a tank and I put 93 octane the rest of the way to fill it up, after I read where 87 is better for them, he only used the best xps synthetic oil so I got the same, I did remove the fuel filter, blow through it and it was very clear made me wonder if the plastic container even had a filter in it I couldn't screw the top off so I figured it didn't come off and didn't want to break it so I just put some cleaner in it shook it around and got some crap out but not much, could the spark wires be burnt from the engine overheating and when they get warm expand and cause my problem. They don't look burnt at all, I've looked into carbs, reed valve and not sure if the will do this or not. The new plugs I put in I checked each time I ran it a little bit and they only had a oily film, maybe a little dark but I would'nt say fouled, I bought 10 so I tried new plugs each time, they darkened but I wouldn't say they got fouled. I don't know what they should look like after 15 min of running but I changed them on the water and it didn't seem to help, is there a oil mixture that can be adjusted, maybe too much oil darkening them too fast, I have no idea and I really don't want to take it to seadoo unless I have I've got this far with it, I can't believe this little thing is trying to give me a hard time. Sorry so long but what do you think could be going on, I mean when it runs good it really runs good, then all of a sudden it does it's thing. It will almost always run good on land with a hose and idle fine 98% of the time on land where I can't run it a lot to check it of course. It again it seems to do it worse in the water when giving it gas I don't know if that's because it runs longer and warms up more than when testing on land or flushing it. I painted the whole thing gold and black, carbs, pipe and head black, all the rest gold turned out nice, if I can just get it to run good. Anyway, Any help is greatly appreciated in advance, or if anyone know someone who might be able to help, please let me know, thanks.
