I have a 2006 GTX Wake Edition.
Running Full Speed
1) Put it on the lake, and was not running full speed. There was no smoke, and no noticeable strange noises. When running 'normal', the speedometer reads 60mph. However, today it only topped out at 40mph. After about 20 minute run time, it started running at 60 mph. I rode for 10 minutes (about), and then took a break. After the break, it returned to running at 40 mph. I then tool it out of the water; to avoid causing any (further) damage.
Flush Engine
2) I hook up garden hose, turn on water, then start the engine. I run for 3 minutes, stop the engine, then turn off garden hose. After close inspection of engine compartment, I notice water has collected in the engine well. I assume the bilge is pumping the water while the engine is running, but accumulates after the engine shuts off. Is this normal, or should I suspect a leak?
**Edit
Just read the manual, and realized I was flushing improperly. correct way: hook up hose; start engine; then start hose. Reverse steps when finished. Still should I see excess water in engine well, or is there a leak?
Also, I suspect the engine not running at full speed is due to the spark plugs. I am just interested if someone has similar experience.
Running Full Speed
Flush Engine
**Edit
