Help my Seadoo
Dadsalone
It was running great. Son rode it out of fuel. Took it home added fuel ran for flushing, had to take it off trailer to replace bunks. Put it back on trailer, now it will it start, carbs not getting fuel. Will crank with starting fuel. What could it be???
Angle of tank when trailer is not on hitch?
Fuel switch 'on' or 'res'. not picking up if really low?
good luck
Any air leak can cause this, be sure the water/filter bowl is clean and the seal works good with a dab of grease to keep it from skidding to the side - if you have grey lines you have to plan a day of replacement and the tiny carb basket filters will need a cleaning also.
