Wolverine
Hey y'all: After 11 years collecting dust, I finally was able to get my 2001 XP running again (luck, and help from forum). Anyway, there are 2 hoses in the engine compartment I have questions about. I have attached a picture. I checked the 2001 seadoo shop manual and can't find any reference or pictures, so I am turning to y'all. The yellow hose (labled 1), is stuffed with styrofoam 4-5" from opening into tubing. The hose appears to run to the rear of ski, exit at the housing. Should this be plugged? I am the original owner and never jammed the hose into to styrofoam sidewall insulation. If it is a venting hose, why is it (intentionally?) plugged? Second question, the check valve that runs to the fuel filter (labled 2) running from bow/port side broke. When I plug in the replacement, is the valve (direction) to allow air out (exit ski) or allow air in?
