Hi (sorry if I make mistakes, but I am french  )
I have a GTX DI (year 2000) that I am using for several years with no problem.
I didn't use it since last year (I have done everything as usual to keep it correctly for the next year).
Now, when I am trying to start up the jet for the first time this year, it is not working.
I plugged the key on the jet and I heard the "bip bip" correctly then I push the "red button" and I heard "tac, tac" and then "brrrrrr" near the battery of the jetski and then the counter is shutting down and I have to plug the key off and on to start testing again but with the same result.
I dont think the problem is coming from the battery as I have fully charged it, and I have also tested by connecting directly the battery of my car; with the same result (except that the "bip bip" is more powerfull when plugged to the battery of my car).
I have unplugged one of the two "plugs" (I hope this is the right term) and then the jet is starting; it is not a particularity of one of the plug, as if I reconnect the last disconnected plug and I unplugged the second one, the jet is starting !
Do you have any idea of what is wrong and how can I fix this issue ?
Thanks a lot for your help.
)I have a GTX DI (year 2000) that I am using for several years with no problem.
