Our 2000 seadoo LRV didn’t have the plugs in so it was full of water. We pulled it out of the lake, took out the spark plugs & turned it over until no more water came out. Then fogged the engine, put spark plugs back in and it would start. So took it back to the lake and it would start, but then die. Took it back out of the lake. We didn’t see any water in the oil, but drained and refilled it anyway. Checked and no water in gas so left that alone. Charged battery (with negative cable removed). Put in new spark plugs. Now it will not start unless I add premix directly in through the spark plug holes. I tried the old spark plugs too just to make sure the new ones weren’t the problem and got same result. Any recommendations on what to try now?
Thanks!
Thanks!
