RESTO Gray Ghost
Paul Bretz
Messages
208
Likes
26
Location
New Baden IL
Water Crafts
many 96 xp's
97 gsx
hx 800
#27
I wonder if the cavitation issue was either the pitch of the leading edge or the lack of sealing from pump to pump shoe. Mine only had a o-ring that went around circumference of pump. Not between pump and shoe. I may use o-ring and a neoprene seal
DanSquires
Messages
273
Likes
22
Location
Blue Springs, MO
Water Crafts
More skis than brains.
#28
The small hub 155mm was desired by racers for a while back in the day. That weird looking impeller they had in there was made by Nu-Jet. It was(is) very fast but there were cavitation complaints off idle on some old forums. I have not run mine yet to compare personally.
The 98GSXL/GTXL MPEM is not a clean swap into the Ghost. It starts and runs good but does a long beep randomly and my VTS gauge is pegged straight up. I think I'm going to have to use the wiring from the 98GSX before I fry something. I lost a rear coil in the RXX the other day plugging a single coil MPEM into it (oops)
Is the ghost MPEM shot or are you just experimenting?
Matt Braley
Premium Member
Premium Member
Messages
6,740
Likes
129
Location
Niceville, Fl
Water Crafts
I can't keep up with it anymore. I've got some really cool skis!!
#29
No it's fine but I wanted to use the 98GSX MPEM and throttle cable to eliminate the TPS. Now I'm seeing it affects other things. I was going to swap to the 98GSX wiring. I
Matt Braley
Premium Member
Premium Member
Messages
6,740
Likes
129
Location
Niceville, Fl
Water Crafts
#31
Sorry to muck up your thread with my confusion Dan. The 97.5 wiring DOES work on the 98 MPEM. The random beeps are a low fuel warning and the pegged VTS gauge is just something mine does half the time. I drilled the 2 rivets in front of the seat and took out the amplifier and the TPS and carb solenoid came out with it.
DanSquires
Messages
273
Likes
22
Location
Blue Springs, MO
Water Crafts
#32
I have yet to even dig that far into the ski to trace the TPS, but if it's only controlling the carb solenoid, then cool, it's going away since the carbs get changed out anyways
Are you still running the reverse cooling? I think I'm going to switch that around to get the cool water to the head first.. probably did that for more EPA junk.
Matt Braley
Premium Member
Premium Member
Messages
6,740
Likes
129
Location
Niceville, Fl
Water Crafts
#36
It's probably controlling timing also.
Yes I'm running the reverse cooling but I have not started tuning yet just break in putting around.
Matt Braley
Premium Member
Premium Member
Messages
6,740
Likes
129
Location
Niceville, Fl
Water Crafts
#38
I could have adjusted the TPS and left it alone.
Yes the carbs must be upgraded.
DanSquires
Messages
273
Likes
22
Location
Blue Springs, MO
Water Crafts
#39
I've been collecting parts and doing a bit of work lately on this ski. I've managed to pick up a UMI w/ RXX steering cable, an R&D exhaust cone, R&D intake, the ADA head with (currently) 50cc domes, and a few other little things.
The top end has been sent off to Fullbore, I'm going to have him go ahead with big Wossner's and just his mild "stage 1" port work.
I also finished off the crank last night, so i'm ready to reassemble a bottom end and see what happens. I got the runout as close as I could, when it finally measured out to .0002ish PTO, .0000 on both center bearings, and .0003ish on the mag I was happy. That's just where it wanted to settle.
Pic, because why not. It's what I've got handy at the moment.
mikidymac
Moderator
Staff member
Moderator
Messages
8,978
Likes
640
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#40
I would go OEM on the seals for this thing. The WSM are not the same quality but close.
mikidymac
Moderator
Staff member
Moderator
Messages
8,978
Likes
640
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#44
I am not sure on the red seals but the WSM ones use a little different rubber on the black ones. It feels a little more plasticy if that makes sense. I still use them on stock rebuilds but for anything more high performance I like the oem ones better. As you I haven’t had a WSM fail but I have seen plenty of the 25+ year old oem ones still holding pressure.
So what are you using to rebuild cranks? You have all the spacers, plates and stuff? I have always wanted to try it but only did outer bearings.
DanSquires
Messages
273
Likes
22
Location
Blue Springs, MO
Water Crafts
#45
First big tool was a 50 ton press.. a small 20 ton would not cut it. It CAN take them apart, but totally not safe.
I had to make a few little custom tools to disassemble and build them, but nothing major. A press plate to fit in the crank webs to separate, and spacers to properly space the center webs. A couple of pipes cut to length to set the two outermost bearings. And I made a stand to measure the runout..
Other than that, just a lot of measuring, and dinging with a brass hammer.
Ankeneyou
Messages
1,805
Likes
18
Location
Columbus, Ohio
Water Crafts
00 XPL
97 GTI
96 XP (4)
97 SPX
95 HX
94 XP
95 XP
95 XP800
89 Kawasucki x2
89 Wellcraft Ecl
#48
Haha, just busting your chops man! Build is looking good! I can't ever seem to find a good condition 97.5 around here, which is why I went with restoring that 97 last year you saw.
My preference was 97.5, 99, 97 but came down to what I could find cheap locally.
DanSquires
Messages
273
Likes
22
Location
Blue Springs, MO
Water Crafts
#49
Oh I know, I'm just easily offended and not at all a sarcastic jerkbag. ;)
That 97 is gorgeous, it would be hard to replicate one that nice.
Tom Cronin has a pretty nice gray ski in St Louis that needs built, if you're still looking
Ankeneyou
Messages
1,805
Likes
18
Location
Columbus, Ohio
Water Crafts
00 XPL
97 GTI
96 XP (4)
97 SPX
95 HX
94 XP
95 XP
95 XP800
89 Kawasucki x2
89 Wellcraft Ecl
#50
Thanks Dan. I'm sure these GSX's will turn out to be beautiful as well. Then you can get those twins back in the rxx so I can ride that too lol.
Users who viewed this discussion (Total:3)
Adsense
Usergroup
