Wave_Raiderz
Hey Guys,
This is an old post that i want to bring back to life as i have a couple questions regarding it.
Here is the URL for it as i can not re open the post.
http://www.seadooforum.com/showthread.php?53129-Fuel-Baffle-Fuse-Replacement
My questions are can i perform the same procedure as he did but on my 95 seadoo xp or will i need a different fuse? Also, do i still have to cut the baffle open and remove the F1 fuse and fill the board where the F1 fuse was with solder?
They way i'm seeing it is I have to cut the baffle open and remove the F1 fuse and replace it with a solder fill, then plastic weld the baffle back together and make an in line fuse splice near my MPEM so its more accessible. Plus add the proper fuse according to what 1648aws said in his post or one one corresponding to the 95 seadoo XP specs that i have no idea about. If someone can help me out here that would be great. Cheers
