Florida Classifieds
I would like to thank Nammer and OCOD for going out of their way to help me out today! My 2nd 99 GSX (project ski) is home and on the trailer next to it's twin! You guys really helped me out here and I greatly appreciate it! Damn, not only did I manage to score a free hull, but thanks to these two, it was picked up and brought pretty much to my door from 3 hours away!!!! I can't thank you two enough!
This ski also makes it two watercraft I have acquired thanks to this thread and Nammer- the first was my 99 Speedster which was a little over two hours from me and Nam gave me the heads up on it!
no prob at all, a pleasure meeting u guys, this has been the ultimate seadoo meet month!
which one r u guys looking at, the white one or the red one? i like the white one more! the whiter the better, so clean
Looks better but no title
Ill take either for the trailer if there take my low ball offer.
Who needs a 787??
I was 15mins from there
:svengo:
When is namer coming back.
Trailer is mine though
:rolleyes:
I did put in a low ball offer since it has no title and doesn't run. We'll see. I'll have an engine and MPEM if you want
:drool5:
Your welcome.
Thats how us Florida peeps roll!!!!
No need to have another unwanted ski go to the dump. Save the 2 Strokes
:grouphug:
That one says clean title?
Two standups on a double for a bone? Under the hoods it's all aftermarket Westcoast stuff. The WTB sections of classified threads are full of people looking for that stuff. Just say'in, there is an opportunity there for somebody.
where are those other guys located? do u think i can spray starter fluid on it and crank it :) i wanted to get one running one and put it on a dolly so i can just go out and play by myself without having to trailer it anywhere
haha, if only starter fluid fixed everything, i was telling oscar, if i have a problem, just take the plugs out and start spraying everything (not everything), like the other day when i called u, starter fluid fixed my prob
Thats a good deal.
Reply htppw-3568088552@sale.craigslist.org[SUP] [?][/SUP]
flag [SUP][?][/SUP] : miscategorized prohibited spam best of[h=2]1996 Sea Doo GSX - $500 (keystone heights)[/h]
1996 Sea Doo Gsx 787 rotax motor comes with trailor and cover , life vest fun ski .
I wonder when he started his thread he was going to sell it
Reply n9ngr-3563685388@sale.craigslist.org[SUP] [?][/SUP]
flag [SUP][?][/SUP] : miscategorized prohibited spam best of Posted: 2013-01-25, 10:27PM EST
Seadoo GTX kustom black pearl paint sea doo jet ski - $2500 (medina)
Seadoo GTX jet ski. This ski was completely dis-assembled, hull sent out to be painted kustom black pearl. Kustom flat black accent stripes and details were applied. Brand new Blacktip front and rear seat, hand grips. Then re-assembled with just about everything replaced or updated. New OEM stainless impeller & wear ring in jet pump - gear lube filled with Amsoil synthetic. Engine is 800cc Rotax 110hp, new top end, WSM pistons and rings. Refreshed rave valves, complete gasket kit installed. 150lbs of compression in each cylinder. Engine painted kustom yellow to match seats & hand grips. Carbs cleanded & rebuilt. All new fuel lines, oil lines. Fuel tank & oil tank, fuel filter flushed/cleaned. Ski has foward and reverse. Gauges all work. No trailer. Roll around cart/dolly to moved & store ski will be included. Starts everytime, water ready.
SEA-DOO GTX - Technical Specifications
Rider Capacity 1, 2 or 3
Fuel Capacity (incl. Reserve) 15.0 US gallons (56.5 liters)
Reserve 3.0 US gallons (11.4 liters)
Oil Capacity 1.6 US gallons (6 liters)
Storage Capacity 33.8 US gallons (128 liters)
ENGINE
Type Two-stroke, Twin-cylinder Rotax®
Displacement 787 cc / 110 hp
Intake system Rotary valve
Fuel Delivery Carburetion
Carburetion (2) Mikuni
Lubrication Variable Ratio Oil Injection (VROI)
Cooling Water, open system
Fuel type Regular Unleaded
DRIVE UNIT
Propulsion System Bombardier Formula water jet pump
Jet pump Axial flow, single stage, large hub
Transmission Direct drive with forward/neutral/reverse
Impeller Stainless Steel
ELECTRICAL
Ignition Digital CDI
Starter Electric
Battery 12 volt
HULL
Type Semi-V with active handling geometry, fiberglass reinforced
EQUIPMENT
Speedometer STD
Info Center (15 functions)
Tachometer N/A
Info Center (16 functions)
Fuel/Oil gauge STD
Analog Fuel/Oil Gauge STD
D.E.S.S™ STD
Mirror(s) STD
