1995hx
I wonder when he started his thread he was going to sell it
Reply n9ngr-3563685388@sale.craigslist.org[SUP] [?][/SUP]
flag [SUP][?][/SUP] : miscategorized prohibited spam best of Posted: 2013-01-25, 10:27PM EST
Seadoo GTX kustom black pearl paint sea doo jet ski - $2500 (medina)
Seadoo GTX jet ski. This ski was completely dis-assembled, hull sent out to be painted kustom black pearl. Kustom flat black accent stripes and details were applied. Brand new Blacktip front and rear seat, hand grips. Then re-assembled with just about everything replaced or updated. New OEM stainless impeller & wear ring in jet pump - gear lube filled with Amsoil synthetic. Engine is 800cc Rotax 110hp, new top end, WSM pistons and rings. Refreshed rave valves, complete gasket kit installed. 150lbs of compression in each cylinder. Engine painted kustom yellow to match seats & hand grips. Carbs cleanded & rebuilt. All new fuel lines, oil lines. Fuel tank & oil tank, fuel filter flushed/cleaned. Ski has foward and reverse. Gauges all work. No trailer. Roll around cart/dolly to moved & store ski will be included. Starts everytime, water ready.
SEA-DOO GTX - Technical Specifications
Rider Capacity 1, 2 or 3
Fuel Capacity (incl. Reserve) 15.0 US gallons (56.5 liters)
Reserve 3.0 US gallons (11.4 liters)
Oil Capacity 1.6 US gallons (6 liters)
Storage Capacity 33.8 US gallons (128 liters)
ENGINE
Type Two-stroke, Twin-cylinder Rotax®
Displacement 787 cc / 110 hp
Intake system Rotary valve
Fuel Delivery Carburetion
Carburetion (2) Mikuni
Lubrication Variable Ratio Oil Injection (VROI)
Cooling Water, open system
Fuel type Regular Unleaded
DRIVE UNIT
Propulsion System Bombardier Formula water jet pump
Jet pump Axial flow, single stage, large hub
Transmission Direct drive with forward/neutral/reverse
Impeller Stainless Steel
ELECTRICAL
Ignition Digital CDI
Starter Electric
Battery 12 volt
HULL
Type Semi-V with active handling geometry, fiberglass reinforced
EQUIPMENT
Speedometer STD
Info Center (15 functions)
Tachometer N/A
Info Center (16 functions)
Fuel/Oil gauge STD
Analog Fuel/Oil Gauge STD
D.E.S.S™ STD
Mirror(s) STD
Thats actually a good price for a custom ski. I wouldn't take less than 3000 for my hx if I sold it the way it is and no less than 3800 after its painted.
Sent from my C771 using Tapatalk 2
