Ater a 5 minute wide open throttle run in 95 degree air temps, I killed the engine and started hitting various spots with my infrared thermometer (measuring surface temperatures).
The jugs were around 140 degrees f. The top of the heads was 120 or less.
What I am most concerned about is the exhaust, since that is what recently burned up on me.
At the junction between the two large exhaust pipes, where the chrome hoseclamp holds them together, and down through the larger diameter of the pipe, it was running around 255-260. Then when it necked down to enter the rubber hose, it was around 245.
Do these sound OK?
Also, how long will the radiator hose I used there last at these temps?
And that clear water line that drains out of the bottom of the jugs and goes out the back, how hot can that get before it melts.
Do these sound OK?
