BMANN06
Hey Guys, I need a bit of info on ECU's. I have an 04' 215 longblock (full ECU/Harness etc). I would like to put this longblock in an 06' RXP.
The 04' ECU Part No is. XXX-XXXXX47
The 06' ECU Part No is. XXX-XXXXX46
Only thing(s) I've noticed so far in changes on the longblock is on the 06' the Oil Separator/High Pressure Oil switch has been deleted, (different cylinder head cover). And the Info Centre (guages/cluster) are different. And the Crankshaft Position sensor is external to the MAG cover. I have the parts to do the 06 conversion (cylinder head cover/vent valve/filler neck etc).
Can I use the 04' ECU if I trick the ECU into thinking the front Oil switch is there? Or is there alot more electrical/software changes within the ECU that will make things like the guages not work etc? If I have to I'll drop the quid on the 06' wire harness and ECU but you guys know these parts aren't cheap so if I can make it work I will.
Any help is super appreciated!!
