kmack
While doing some general winter maintenance the other day, my older 'doo appears to have some bearing issues.  I was starting both Seadoos up and running fresh fuel through, but I was having problems getting my '93 SPX started and running.
Here's what I found out (see pic). The bearing on the driveshaft (right red arrow) will only turn in one direction, the same direction as the rotation of the shaft (yellow arrow). The rubber shroud has also become separated from the hull where the shaft runs thru (left red arrow).
I don't think this is supposed to be correct and I think the bearing (right red arrow) is bad. Especially since it will only spin in one direction (kind of like a sprag clutch).
I have a maintenance manual for my '97 GSX and it also includes info for a '97 SPX, so I think I may be able to figure this out, but I have a few questions before I get started.
In the manual, it mentions using a shaft puller to get the shaft disconnected from the engine. Is this required, or is it possible to get them separated another way? Once I get the shaft out, how hard is it to get the old bearing off? Any tips or suggestions?
Once I have everything replaced, will I need to worry about alignment issues with the driveshaft? As long as I don't move the engine on its mounts, it should be ok, right?
How do I reconnect the rubber shroud back to the hull (left red arrow)? Is there a glue that is required?
I think that's all for the questions for now. I'm suprised that this bearing went bad because I've kept up with greasing it all last year (every other time we used the ski). But then again, stuff is still going to fail at some point.
I plan to start this work sometime in the next few weeks. I want to make sure I have time to get it fixed before riding season starts again here in S. Texas (which will be around March).
Thanks in advance for any help.
