Draining oil and Gasoline
derrick
How do you drain the oil and gasoline in the jet ski. I looked at the service manual but I cant figure out how to disconnect the fuel line hose and drain. Can anyone help me out? it will be greatly appreciated! Thanks.
The best way to remove any fluids in a seadoo is the siphon method. In oil injection, most tanks can be removed if the injector reserve tank needs to be drained.
Karl
just did mine. any autozone or walmart should carry something to use...i used the hose that you use to connect the gas tank to an outboard motor...alil more expensive but Im just going to use it as a spare for my skiff
Like draining the gasoline, the manual shows a picture on how to disconnect to drain, but its confusing. You have an easier way of draining it, or disconnecting it?
I might be wrong, but only the oil reservoir has a bottom outlet. You can unhook that and drain the oil out that way...I siphoned out as much as I could get flowing out of there and then pulled that oil line off the bottom nipple and put a 7-11 slurpee cup down there to catch the oil from the bottom.
But as far as the gas tank...Pretty sure the only openings are on the top of the tank (connection for where you fill the tank and where the baffle goes)
I attached the fuel system diagram for your fuel system. Taken from bikebandit website.
For me...I removed the clamp for the large black "filling tube" and gave it a good tug to remove and then siphoned it out through that hole. If you want to remove your tank, you should be able to remove both the baffle and filling tube and remove it through your front compartment. Atleast thats how my 97 was.
