Lostcanuck_99
I bought a used 2008 RXT with 12 hours on it...fantastic unit.
Unfortunately, I have one minor problem (minor is relative). When I put the DESS key onto the post the unit will start and run normally. However, when I pull the key off the DESS post, the unit keeps running. This is an intermittent problem; sometime it shuts off, sometimes it stays running. The start/stop button works properly. I have to disconnect the batter to stop the audio beeper.
Is it just the DESS switch or the MPEM module. Given that I need to disconnect the battery, I suspect it is the MPEM module.
Any support would be great.
Cheers,
Randy
Cheers,
Randy
