Because of machining tolerances seadoo made different thickness gaskets to set the distance between the cylinder head and piston crown known as the "Squish" clearance.
Too much clearance and you will get poor performance. To little clearance you will get detonation and destroy the piston.
You have to measure it to determine what gasket you need.
