For starters I have a 717 engine with a single carb... and this is in an 97 GTS
So I decided to switch to premix this year... I took it to the lake today and it worked ok but there is a little bit of hesitation from idle to half throttle, I have to easy the throttle up in order to get the engine to catch up... I also replaced the rings over this year so at the current moment I am running the mixture a little strong to help the rings set in... I guess my question is should I leave it alone till I get the rings set in and see how it runs with 40:1 mixture or is there maybe a carb adjustment I need to make because I am now premixing...
Thanks
Chris
Thanks
Chris
