I test drove a 4-tec Sportster (155 hp) yesterday and it had some cavitation and top end issues. It wasn't efficient getting planed off, and it topped out at 40-43 mph via GPS.
I eyeballed the impeller and wear ring and it had some small chips and what looks like warping on one blade. The wear ring has some mild scoring but nothing deep. I've never owned a jet boat so I have no idea how much damage an impeller can take before causing a performance hit. My question is does this photo show enough damage to explain the sub-par performance?
Is rust expected on the shaft? The was quite a bit, but I don't see how rust here can be avoided in saltwater use.
The seller acknowledged the existence of the problem and intends to have a mechanic take a look. What should I require the mechanic to check other than what was described above?
This is a 2004 with 50 hours.
