Challenger motors not turning over with spark plugs installed
jonjam
Recently purchased a 1998 challenger 1800. When I went to buy it both motors started and we ran them for about 15 seconds. Everything seemed to be fine.
Trailered it home and took it to the water the next day. Neither motor would rotate. Thinking it would be a battery issue, I installed a new one. Still will not rotate. Pulled the spark plugs and both motors will cycle as if trying to start. Nothing sprayed out of the cylinders like it had any water or oil. New to seadoo and not sure how it can run one day and not rotate the next day on either motor. Any advice is appreciated.
i would suggest you check all your connections specifically your grounds. Even if your grounds are tight there can be corrosion that can ruin a proper connection. Take them apart and sand them clean.
I'm not sure what your asking. The motors would not rotate with a new battery but when you removed the spark plugs the motors did rotate?
I think your key fob was loose or a wire is loose behind the dash.
Each motor has its own starter.
I would use a volt/ohm meter and see if there is 13v going to the starters while someone is pushing the start button while I hold the black volt meter wire on the battery negative and the red volt meter wire on the starter wire post. If there is no voltage start checking fuses. After that all you need is fuel/oil, spark and compression.
