Challenger motors not turning over with spark plugs installed
jonjam
Recently purchased a 1998 challenger 1800. When I went to buy it both motors started and we ran them for about 15 seconds. Everything seemed to be fine.
Trailered it home and took it to the water the next day. Neither motor would rotate. Thinking it would be a battery issue, I installed a new one. Still will not rotate. Pulled the spark plugs and both motors will cycle as if trying to start. Nothing sprayed out of the cylinders like it had any water or oil. New to seadoo and not sure how it can run one day and not rotate the next day on either motor. Any advice is appreciated.
i would suggest you check all your connections specifically your grounds. Even if your grounds are tight there can be corrosion that can ruin a proper connection. Take them apart and sand them clean.
