Stevie White
Had the hose that connects the resonator to the exhaust port fall off while riding. The bilge filled with water and the pump was working overtime to pump out the bilge. Symptoms were at first lower rpms despite throttle position, next an over temperature warning, then engine shutoff, cannot restart. Lucky for us, we were close to the boat launch and a passing boater towed us in. We were very heavy with water, but were able to drain the bilge quickly on trailer.
Here is how we fixed it.
Tools = Socket set. Flat head screw driver.
- Shut main Battery switch off
- Open the engine compartment and prep the area with life jackets and cushions. We had to lay on top of the engine to reach the hose. Be careful not to break any top engine components or disconnect the TPS connector like I did
- Take a picture of the intercooler and remove it. This allows easy access to work area.
- Lossen 2 exhaust port hose clamps
- Carefully move resonator and hose towards engine compartment opening.
- Attach exhaust hose to resonator. Tighten the 2 hose clamps.
- Insert resonator and attach to exhaust fitting. Tighten the 2 clamps.
- Install the intercooler.
- Account for all tools, hose clamps, and fasteners. Check top of engine for all connectors.
Back in the water:
- Turn main battery switch on, stay attached to trailer, start engine, and look for leaks.
We were good so we launched, however, the engine light was on, and the computer only allowed limp mode back to dock. This is where I discovered that I removed the TPS sensor with my beer belly during the repair. The display gave us the fault code. Once the connector was installed, the fault code went away but engine light stayed on. On next launch, the computer allowed only 5000 rpm but no fault codes. Subsequent small rides around dock allowed for greater and greater RPMs and eventually the engine light went out.
Hopefully someone finds this helpful. I have a great respect for Boat Mechanics, especially their ability to contort their bodies to work in impossible confined spaces
Back in the water:
