ok i have a 94 seadoo xp with a 650, carbs are all cleaned out, rotary valve checked twice, 130psi in each cylinder exactly, good gas good spark(new plugs) but this damn thing will not start. so i grabbed a timing light, marked the rear flywheel at TDC with corresponding mark on engine caseing, cranked it over while holding the timing light and the marks are way off, almost 90 degrees off from what i could see, but drastically off. so checked the woodruff key GOOD!, ohmed out the coil on black and black/red, got 147ohms according to manual that is in spec. this jet has timing issues, where else can i go with this?????
