Okay, so I finally got the exhaust seal on last friday, took out the boat saturday. First check: Does it float? (This was the problem before)
Backed the trailer up, no water came in. Yay! Started the engine, and still no water coming in. Double yay!
I did notice that it was REALLY loud though at the 1500 rpm idle, sounds like there's ball bearings in the crankcase or chunks of steel floating about in there. Revved it up to about 3500 rpm, sounds great, just like all the other 2-stroke PWC's I hear buzzing about in front of the beach.
So thats my first question: How much noise is normal at idle? I was thinking pump issues, but would it sound just fine at speed if there was a pump problem?
Next we spent the day tooling about the lake, runs good, but isn't that stable through the rough water, I guess I'd need a bigger boat to change that... tried adjusting the trim up and down, neither position seemed to make much difference for stability.
Got home and apparently wasn't wearing enough sunblock, starting to look like a lobster.
Then yesterday decided what the hey and brought the boat out again, headed up to a calmer part of the lake, its beautiful up there, going to stick to that part for the most part now.
Tried to get on it, managed about 43mph on the speedo and 6950rpm. This was with the trim all the way forward, only about 39/40mph on the speedo with the trim centered or back.
And that's my second question: Is that top speed on my '97 challenger, or should I be getting more speed/more rpms out of it on smooth/windless water?
Even if it still needs some work, not bad for a $500 boat, $50 of title work, and another $250 or so and about 15 hours (my time, not dealer time) in parts and repairs to the boat and trailer
