dodson.james6434
2001 Seadoo GTX RFI. Ok guys I’m hoping someone can please help me here. I had a new SBT motor installed as well as a new starter. The mechanic put in a new rectifier which was blowing the 20 amp fuse in the rear electrical box. I disconnected his rectifier and installed the old one and now the 20amp fuse is holding. The problem I’m having is voltage is not exceeding 12.6v while running or when engine is rev’d. He advised that he checked the voltage coming from the stator with rectifier disconnected and was getting 14.6 volts. Is it possible the old rectifier is not doing its job? Or possibly a ground issue? Battery ground is running to metal frame that motor sits on and I’m getting proper voltage to that point. Can someone please steer me in the right direction. I’m an 18 year electrician but don’t know much about motors. Thank you guys!
