Porschephreak
Are these safe to use? http://www.harborfreight.com/12-volt-jump-start-and-power-supply-38391.html
I'm sure Lou or the Doc will tell you for sure but our local dealer has used them for doo's out in the parking lot if that helps.
They should know I suppose!
i'm guessing that the dealer might use one thats NOT from harbor freight.
my personal thought with no science behind my opinion... is don't use it, just charge your battery before you go to the ramp.
i was under the impression that the added capacity of the larger battery / boost setup was because you will fry the MPEM. the system can and does pull all available juice to start the ski, and if you increase the available juice, the system gets overloaded...
but that's just my guess.
It all depends on what electrical engineer you talk to.... In theory a battery will only supply as much amperage as the starter can pull. This is why you can use a car battery as long as it is 12V and the car is not running. We know the MPEMS are voltage sensitive and why a running car with the alternator is very well known to fry the electronics because it is providing 14V.
Just play it safe and stay away from the boost boxes because it is unknown what voltage or amperage they are providing. If you have to crank the water out just use the car, not running and make sure you connect the negative last and remove it first.
PS: never let the magic smoke out of any electronics.
