rumblefish73
Friend has a bad ECU on his 2006 RXP. Won't control the injectors and gives codes P0261 P0264 and P0267.
Put 04 ECU in his and I'm able to fire off the injectors with Candoo but get codes P1200 “blow-by-valve shorted to ground or short circuit” and P0520 Oil Pressure switch faulty, which may be because they used a different switch in 04 vs 06. Would it be ok to start and run it anyway?
Can I reflash 04 ECU with the 06 info by using a different program or does someone know somebody who can do this?
