rusty nail
I am at the tail end of a 98 speedster project and i installed a replacement 787 motor on the port side. This replacement motor/carb setup does not have the additional accelerator pump. Should i install the original accelerator pump and carb that came out of the boat? What is the benefit of the additional acclerator pump? Can you have two separate systems under one hood? Will i notice a difference in performance? And lastly, are the carbs any different and if not, can i simply add the accelerator pump to the replacement carb? (or are the carb setups different)
