A Little Help Please...
Davefer
Hi All
My Boss has a Sea-Doo which he wants to sell. The seat is ripped and he wants to have this repaired before the sale.
He's told me to remove the seat with a view to taking it somewhere to be repaired.
I cant get it off.
I have taken out the bolts that hold on the tie line thingy on each side and now it looks like I have to remove the bolt that's inside the boot under the seat.
Is this correct? I don't want to take it off unless I need to because it looks like it will be a real pain to get back on.
Any advice will be very much appreciated.
Thanks in advance
Dave
Assuming it is a PWC, since you posted it in the PWC section, those seats just pop off with the press of a button or lever, in most, if not all, cases.
What model is the ski? Most that I know of have a lever under the rear of the seat that you press up, and the back of the seat comes up, then slide it back off a hinge.
there should be no screws or bolts.
If it is a boat, that is something different,
Post your year and model i.e. 1996 XP etc.
My apologies....I had that info in my first attempt but it got lost when I tried to post it.
It's a 1998 Bombadier XP Limited.
It looks to be solidly attached through the middle of the boot under the seat but I really don't know for sure.
yup, they're a pain. Remove the bottom shield, the hose clamp, to pull down the shock boot, then remove the bolt holding the shock, then you can flip the skis' seat up
