Some times ago, my throttle body died... when i push the throttle to +6800 rpms, i start getting some errors in the gauge followed by a check engine light with the codes p1120 and p2620. This codes makes reference to the TPS sensor inside the body throttle.
The bt on my seadoo:
After remove the top cover from i found this, the TPS board.
Without going so deep in the values check with the multimeter following the manual and that kind of things:
This is the normal wear of a TPS sensor board:
A peugeot 308 bt, that appears to have the same TPS board (i cant find one to try)
I've tried to found a way to solve that, but i couldn't...
The alternative:
Then i started watching for an alternative to the OEM part (in my country is about 1800 u$d) and after read about 20 posts thats it what i can collect:
Seadoo releases 3 body throtles reviews (i don't know the exact dates, but it's an approximation):
420 892 590 (until 2013?) <---- Bosch
420 892 591 (~2014 to ~2015?) <---- Bosch
420 892 592 (actual part) <---- Dellorto
I read a post that talks about one particular body throttle, and bought one to try, and IT WORKS! Just plug and play.
It can be found on: Audi A4, PASSAT 1.8T, Volvo XC90 and in some Mack trucks.
Audi OEM: 06B133062M
Bosch MPN: 280 750 009
Another Brands pn:
- 99660511500
- 06B133062B
- 058133063P
The only difference between this alternative, is the gasket.
The OEM part have a bigger holes for the screws because the OEM rubber gasket get inside the holes.
The Bosch bt (for audi) use a regular gasket (buy one of this if its not included). and some exagonal screws.
Bosh Rotax / Bosch
OEM Gasket / Common gasket.
Where to buy:
Audi, VW Throttle Body Assembly (A4 Passat 1.8T, Bosch) 06B133062M by Bosch
SeaDoo Throttle Body 420892592 420892591 420892590 0280750505
57mm diámetro para Audi A4 A6 Quattro electrónico Cuerpos del acelerador Válvulas 1.8 T 06b133062m 0280750009 en Cuerpo del acelerador de Coches y motos en AliExpress.com | Alibaba Group
Tech info:
http://www.bosch-motorsport.de/medi...ottle_Body_Datasheet_51_en_10726070795pdf.pdf
Important!!!
It MUST be Bosch. I tried with a replacement of 280 750 009 of a another brand and it doesn't work... When i plugged the key i got a long Beeeep an then "protection mode". I suppous that the TPS value are diferent.
Well... thats all for now... i hope this info can help to another.
And sorry if some informations is wrong or missing, and if you have some info to add that can be useful, please let me know.
The alternative:
Another Brands pn:
- 99660511500
- 06B133062B
- 058133063P
Bosh Rotax / Bosch
Where to buy:
Tech info:
Important!!!
