aquaman2020
my 99 spx will intermittently start cranking without the safety switch installed or the start button being pushed. sometimes it operates normally. i will install the switch, get the double beep, press the start button, and the engine will turn over. sometimes, pushing the stop button or pulling the safety switch will not stop the cranking and the battery must be disconnected. other times, as soon as the battery cable is touched to the terminal, it will start cranking. since the engine cranks fine, i assume the problem is not with the battery or starter. my thought is a short somewhere in the ignition circuit. does this seem appropriate?
any thoughts or suggestions would be appreciated. thanks.
