Added information , your thoughts please.
Since nothing was turning out as a fix, i decided to remove the hoses from the crankcase to the rave valves. The lines were ver ver full of sludge. I flushed them out with carb cleaner and all is clean now the valve diverting the pressure was also full.
Please tell me something. The crank case is possitive pressure true? An amount of vapour , not sure sure if it was and oil mix , but it was not gas. The check valve has great amount of tension. I really had to blow hard to overcome the valve. I can only assume that is normal based on the pressure coming from the crank case. The exhaust rave is from a different source. Any thoughts or does this give anyone a new avenue to direct me through? I started it and same issue but at least found something not right
