Wrong sparkies would do that, use BR8ES. Pull the return fuel line off the carb, put a short line on the return nipple and into a catch bottle then crank it over.
that will tell you if the fuel route is clogged. Then pull Supply off carb, put the
supply line in a catch bottle and put 5-10 lb air
pressure into the return line. This will tell you if a clogg is else where. If the fuel
routes, Your carb has the clog. HTH
