97 Seadoo XP 787
Ok several issues.
No spark, beeping, or engine activity.
I have seen several threads about this issue before. I have checked everything to make sure it was not my battery, ground wires, fuses, corrosion on connecters. I used electrical cleaner and dielectric grease. Tried jumping the starter solenoid using a car battery still nothing. Ski has fuel and good compression. With lanyard plugged in there is no action at all. No beeps nothing. Gauges do not turn on or light up either. I guess there is a standard mode and advanced mode. I do not think I can get into either of those. Also with spark plugs out, I can manually turn the drive shaft. So that has been checked. Beeper issue? DESS post? I should be hearing something right? Not getting spark either could it be ignition coil? Every connection is secured and cleaned.
I want to include this ski was working fine when I bought it back in Feb 2013. With the season around the corner getting it ready now. It will not turn over. When trying to get it started a week ago, after pluggin the lanyard in, I would get two beeps and the engine would try to turn over. This week no beeps, nothing at all. Is there a way to test the MPEM to make sure the MPEM is seeing the lanyard plugged in?
