I have a 97 seadoo xp it idles great and has great throttle response, perfect compression (150psi both cyl.) the rave valves are clean and it will turn over freely by hand with the spark plugs out. but when out on the river it will run great for about 5 min then just die like a kill switch kicked in . Then it will start back up after about 3 min and run fine for 5 min and then it does it again.The motor is not hot i can touch it and it is just warm.I replaced the coil and it still does it.
I just had it rebuilt,so i assumed that it was something electric seeing how it cuts out so quick and starts back up fine, if yo know what could be wrong please help.thanks
