jemery.wa
I picked up a 97 GTX that needed work, which seems like it needs 1 of everything! at this point it will run fine in the water on the trailer and will even take off and rip pretty good but it is having a problem of dying after it runs at around 6k for more than 30 sec, sometimes after it dies it won't crank until you remove the key and put it back in. At that point sometimes it will fire right back up and other times it acts like the battery is dead, eventually it will fire up again. when it dies it will just shut off. It happens on both normal and reserve fuel selected. I will list the things that I have done so far.
new top end
oil injection block off kit.
replaced Tempo fuel lines
cleaned out fuel selector, was clogged on reserve side
carbs rebuilt and tested pop off seems to be around 35 and hold pressure
reset screws to factory settings
replaced aftermarket MPEM with another new one (same brand but brand new)
tested DESS post, was fine
tested start button, was fine but seemed to have a 1 sec delay before resistance drops.
tested charging voltage and it checks out good
replaced jet pump, wear ring was installed backwards
replaced drive shaft and carbon seal, driveshaft was partially stripped at PTO due to no grease boot.
I have 2 96 GTXs and even some extra parts for those but the 97 uses a different MPEM so I can't use that to test. My speedometer doesn't work but I believe that is a problem with the speed sensor wire, I found a burn spot in it and neither the analog or digital gauge. The Buzzer doesn't work at all, I do have a spare that I have used when I was trying to reprogram the old MPEM. I will say that even with the new MPEM the rev limiter seems to be set at around 6500 rpm which is low. I have tried with the temp sensor connected and disconnected and it doesn't seem to matter.
I am at a loss of what is going on with this thing.
new top end
